X21 phone. 3G problems.
Greetings!
I have bought a phone from china (Product code: CVFD-M330). It works fine and such but my 3G connection won't work, calling/sms/mms works fine.
On the desc it says:
3G WCDMA: 850/2100MHZ
2G/2.5G: 850/900/1800/1900MHz
It has two slots to put the sim card in and when I borrowed my friends 3G only simcard I barely got some connection but when I put a "non-3G" sim in the Slot 1 and my 3G in Slot 2 it's like I have my card in Slot 1, no difference.
I can't put my finger on what the problem might be, recently bought a 10
I recived another phone today from china a Bedove HY5001, the X21 I think also was a Bedove.
I figured out the problem why I coulnd't connect with 3G.
Deep in the settings I found APN setting was set for wap.xxx.xxx so I just changed it to "internet" and now it works.
Mabye others with 3G issues should change APN to internet. I had 2 different phones with same problem and both were set to wap.xxx.xxx.
