krishnaveni
Hi i have to develop one xml parser example with pagination examples.
Here i have to display 10-10 item per page.how is develop this.please give me some idea.
this is my android code:
In this link http://192.168.1.168/xcart432pro/orderdetails.xml have 200 products.but i wish to display 10 products only.then the next 10 product is display same activity after load few mints.how can i develop this.please give me some ideas.
Code:
package com.example.androidhive;
import java.util.ArrayList;
import java.util.HashMap;
import org.w3c.dom.Document;
import org.w3c.dom.Element;
import org.w3c.dom.NodeList;
import android.app.Activity;
import android.content.Intent;
import android.os.Bundle;
import android.view.View;
import android.widget.AdapterView;
import android.widget.TextView;
import android.widget.AdapterView.OnItemClickListener;
import android.widget.ListView;
public class CustomizedListView extends Activity {
// All static variables
static final String URL = "http://192.168.1.168/xcart432pro/orderdetails.xml";
// XML node keys
static final String KEY_SONG = "Order"; // parent node
static final String KEY_ID = "orderid";
static final String KEY_TITLE = "orderid";
static final String KEY_ARTIST = "payment_method";
static final String KEY_DURATION = "total";
ListView list;
LazyAdapter adapter;
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
ArrayList<HashMap<String, String>> songsList = new ArrayList<HashMap<String, String>>();
XMLParser parser = new XMLParser();
String xml = parser.getXmlFromUrl(URL); // getting XML from URL
Document doc = parser.getDomElement(xml); // getting DOM element
NodeList nl = doc.getElementsByTagName(KEY_SONG);
// looping through all song nodes <song>
for (int i = 0; i < nl.getLength(); i++) {
// creating new HashMap
HashMap<String, String> map = new HashMap<String, String>();
Element e = (Element) nl.item(i);
// adding each child node to HashMap key => value
map.put(KEY_ID, parser.getValue(e, KEY_ID));
map.put(KEY_TITLE, parser.getValue(e, KEY_TITLE));
map.put(KEY_ARTIST, parser.getValue(e, KEY_ARTIST));
map.put(KEY_DURATION, parser.getValue(e, KEY_DURATION));
// adding HashList to ArrayList
songsList.add(map);
list=(ListView)findViewById(R.id.list);
// Getting adapter by passing xml data ArrayList
adapter=new LazyAdapter(this, songsList);
list.setAdapter(adapter);
// Click event for single list row
list.setOnItemClickListener(new OnItemClickListener() {
@Override
public void onItemClick(AdapterView<?> parent, View view,
int position, long id) {
String Orderid= ((TextView) view.findViewById(R.id.title)).getText().toString();
String Price = ((TextView) view.findViewById(R.id.duration)).getText().toString();
String Description = ((TextView) view.findViewById(R.id.artist)).getText().toString();
// Starting new intent
Intent in = new Intent(getApplicationContext(), SingleMenuItemActivity.class);
in.putExtra(KEY_TITLE, Orderid);
in.putExtra(KEY_DURATION, Price);
in.putExtra(KEY_ARTIST, Description);
startActivity(in);
