Xperia Arc Problem!
yopolonu
I tryed to make update to my phone and after a minute the phone went black(turned off) and doesn't open.doesn't charge.and the phone has 1 month bearely used.
someone knows what should be the problem?
I'd suggest you to run the Repair Phone option on the PC Companion. That will attempt to re-install the software on the phone and that should fix your phone.
