Help Xperia C dead after installing CWM!!!
JasonLong
Member
Hello.
I used below link for upgrading my Xperia C to Lollipop but after Installing CWM my phone not turn on !!! :
http://forum.xda-developers.com/son...-lollipopxperiacb-2-16-stable-tested-t3011897
According to the below link :
http://forum.xda-developers.com/showthread.php?t=2696987
I downloaded "Mobileuncle Tools" and "recovery.img" and it ask me for reboot my device and when I did it my Xperia dead and can't turn on. My cell phone is turned off and I can't turn on it.
Any idea?
Thank you.
If the battery comes out, remove it for a minute or so then reinsert it. Then try the volume down with it off and connect it to the PC.
Battery can't removed and I used reset button too but problem not solved. When I hit "Volume Down" key for a while it show me red light but not happen :(
I don't know why someone upload bad tutorial and corrupted files :(
You could try this. http://forum.xda-developers.com/showthread.php?t=2631810
I have never used "Mobileuncle Tools" I always use fastboot or other methods to flash recoveries on Sony devices.
At this point you are limited on options so it's worth a try or even a few tries.
It sounds to me like you flashed the wrong recovery. Sony devices are extremely specific as far as what recovery will work or not work. Always verify the firmware version and make sure everything matches.
Xperia C not have Fastboot mode and I just connect to it via "adb". I must Flash my phone via Box and try again.
Must I unlock the boot loader first via cheat code?
