Xperia Play help? - Newbie
Darryl01
Hi all,
So my xperia play arrived yesterday. The problem is Fifa 10 (preinstalled) uses the old control layout. X to switch player instead of L1 etc..
This makes it impossible to play as I am used to the normal layout. I know it can be changed as one fo the pop up hints said to change oit in the control centre.
My question is then - Where is the control centre? how do I change Fifa 10 controls?
Thanks In advance Guys & Gals
Darryl
