Xperia Play SD Card Help
Meteoroid
Hey , Im getting an xperia play and people are complaining that you have to move everything on the sd card. Is there a way that they can move on to the sd card automatically? Also what sd card is it? Micro Or standard? and what type is 'faster'. Thanks.
You have to move the apps manually and not every app supports the option to be moved to the SD card. This phone uses Micro SD cards.
