I had my Xperia Play for 2 months now, And so I was playing A game called Roman Empire for Android, then It was forced closed. Then I decided to play later, then I received a message and the messaging was forced closed also. I kept opening the messaging but it always force closes. Then a notification popped out that the battery was getting low, but I couldn't find my charger and then I thought I'll just charge it later. Then the battery died. A few hours later I found my charger and plugged in my Xperia Play. It was perfectly fine, the power switch was orange (means that it's charging), and the screen had a battery picture with a lightning. Then after charging i turned on the phone, the SE text showed up then a few seconds later the logo showed up. It was perfectly fine until the phone suddenly turned off, then the SE text showed up again then the logo, then the phone went off, then it happened again! I think this is what they call the "boot loop"? Please answer ASAP. There is a PVP event on my favorite game, Roman Empire and it will only last until next week! HEEELP .
BTW, I am aware of the thing called CWM but I cant use it because my phone is stuck on boot
And lastly, my phone is not rooted.
