OK, so my Pro has finally been up-dated to ICS, which is lovely and super and all that. However an odd (minor) issue has occured with the keyboard and it's not the QWERTY-AZERTY problem that seems so common.
The mode toggle characters have now been "mixed-up" for lack of a better phrase, so they do not all corespond with the symbols show on the keyboard. For example, the @ key does not produce anything at all when pressed and when the mode toggle is switch it shows a colon not an apersand as it should. A toggled Z should have no symbol but now produces an open bracket while the open bracket key (toggled K) shows a comma.
The number are fine, its just the bottom couple of rows that have an issue.
Any one else had this or have any solutions?
Thanks
(I'm in the UK and running a unlocked device on O2)
Thanks
