Hi there I have moved your post to its own thread as you may get more answers that way.
I don't know about the numbers thing but I also use an app called MeContacts and you get a numerous pages of tiles, each tile being allocated to one contact with their contact picture displayed if you have it, if not you can add images if you want. You can set it up to dial/sms from there. You can name pages ie friends, family, work etc.
I also use an app called Gesture Search which you draw with your finger the first letter of your contact (you can add further letters to narrow it down) and then hit the green phone next to their number to dial.
Both are just a bit quicker than trolling through Phonebook, selecting your contact then selecting the number and then dial.
Hopefully others will chip in with other suggestions.
i do having problem. did you find solution?is there a way to set dialer keys or numbers so I can speed dial contacts like the 1 is set for voicemail? Thnx Jay
