Goto Settings and at the top do you might have an option called Sony Ericsson....click into there and if there is an option to Setting Download.
That should do it.
Now a lot of phones don't have that option. You may need to do this manually...if you don't have that Setting Download button do this:
Settings->Wireless and Network Settings->Mobile Networks->Under Network Operators, make sure you have the right one selected.....next....click into Access Point Names and make sure you have that created. If there is nothing there, you will have to manually add the information.
For that you might need to look it up. It should be something like this depending on who your cellular provider is.
<name> att
<apn> wap.cingular
<proxy> wireless.cingular.com
<port> 80
<username> not set
<password> not set
<server> not set
<mmsc> http://mmsc.cingular.com
<mms proxy> wireless.cingular.com
<mms port> 80
<mcc> 310
<mnc> 410
