When I upgraded to a Sony M2 from the Xperia E last year, I was absolutely delighted. After a great year with the M2, it got dropped and the case cracked, so I decided to get a new phone. I was tempted to get another M2 as I was so happy with it, but in the end went for a Z3 because the prices had come down quite a lot, and it looked a much more powerful phone.
I have to say I'm a little disappointed so far. The 128GB SD card capacity is great, camera is great, but I've had a lot of teething problems (such as when I first got it, updating the software again and again and again because it kept prompting me to, when in fact it was just installing the same thing over and over again).
Now I seem to have an issue with the battery indicator and not sure if this is a fault or a feature.
It happened a few days after I got the phone, I was stuck on 94% despite using the phone for half a day, and had to restart. No problems since then, but today it just suddenly stopped on 55% and I noticed because I was using the phone a lot with screen on, and battery level wasn't moving. Both the native battery indicator and GSAM report exactly the same, both stop at the same time.
It's kind of important to me to know whether my phone has 55% left, or 10% and at the moment I have no real idea, because it can go for 2 hours and the battery indicator doesn't change, for all I know i could be sailing dangerously close to zero.
On both occasions, when I've rebooted, the percentage has come back exactly as it was when I rebooted, and then started dropping at a normal rate - so the actual percentage doesn't seem correct, as it was stuck on 55% for 2 hours of screen use, then rebooted, and was apparently then still 55% full and only now is it starting to drop - but it could have lost 30-40% in the time it wasn't dropping.
Could this be a faulty battery or is it a problem others have had? OS is android 5.1.1 - maybe it needs Marshmallow to sort this nonsense out? Not sure if it's android itself or a Z3 issue?
Thanks for any input anyone has!
