Root Xposed for android lollipop!
Finally it is going very well!
PROPERLY IN ALL ANDROID DEVICES 5.1 L70
download the updated framework in this link
link to the apk
Doing the process correctly, will work no worries, I'm ultilizando and there is no error, this update does not occur optimized for bootloops
I am not responsible for loss, boot loop and any error.
Now we can install XInternalSD and BootManager to better experience as well as other modules :p
Warning not all modules are running, so it will be spending a list of some that are already working properly:
COMPATIBLE modules
    • All Notifications expanded
    • Always expandable notifications
    • Amplify
    • Audio Privacy
    • Battery status plus
    • Boot Manager
    • BubbleUPnP
    • Burnt Toast
    • CrappaLinks
    • Enable Ambient display
    • Enable notification ticker for Lollipop
    • Flat Style bar indicators
    • Flat Style colored bars
    • Flat Style colored keyboard
    • Flat Style module
    • Force Immersive module
    • Google Search/ Now API
    • Hide Network Indicators
    • Keepchat
    • Lollipop power menu
    • Map zoom invert
    • MaxLock
    • MinMinGuard
    • Native Clip Board
    • Network speed indicator
    • Niwatori
    • No wireless charge sound
    • Playstore Changelog
    • Rootcloak
    • Sense 6 transparent recents
    • SIM number change
    • Statusbar scroll to top
    • Swiftkey goodness
    • swipeback
    • swypetweaks
    • tinted status bar
    • Unicon
    • VolumeSteps+
    • WifiKeyView
    • Xinstaller
    • Xposed GEL
    • XSuite
    • Xtended Navbar
    • XToast
    • Youtube Adaway
    • Youtube background playback
    • XInternalSD
    • XSSID Indicator
NON-COMPATIBLE modules
    • Activity Force New Task
    • Advanced power menu+
    • Battery History
    • Complete Action plus
    • Custom share
    • DynamicAlarm icon
    • Enhanced toast
    • Fake Wifi connection
    • G2 Tweakbox
    • G3 Tweakbox
    • GPS Notification
    • Greenify
    • Immersive Mode
    • Keep trash
    • MinMinLock
    • NFC LockScreenOff
    • No Lock home
    • Notification count
    • Noverflow
    • Outgoing calls chooser
    • PinNotif
    • Playstore link in app
    • Recent app cleaner
    • Resflux
    • Screenshot delay remover
    • Sense 6 toolbox
    • Shake to undo
    • Shortcut in app info
    • Snapprefs
    • Statusbar Gestures
    • Trimnot
    • UnbelovedHosts
    • Wakelock terminator
    • WanamKit
    • Wear Messenger
    • Whatsapp X
    • XHangouts
    • XHover
    • Xposed Lockscreen wallpaper
    • Xposed preference injector
    • Xposed Torch
    • XStana
I have tested the new Xposed Framework and its not working on both NamelessRom 2.1 and Paranoid Android 5.1.1. I fresh installed both the roms(just to be sure) and still not working. I am trying CM12.1 now and will update later.
  • unfortunately is not succeeding when activating the modules, better wait in a fixed update of the creators, will take the post of the air.
Use test and answer me if it works, if you run out bootloops to install the module, hopefully yes. do not forget to respond here to inform me will go a long way
I finished testing on NamelessRom 2.1, and at first it wasn't working then I figured that I selected apps on sdcard in settings. Thats why Xposed and its modules were on Sdcard and it wasn't working.
Bottom Line after installing Xposed newest. Make sure xposed apps are on internal. (First install BootManager, if this works all the other working ones on OP will work.) Cheers.
OK guys here is a successful completion of my xposed modules collection. And this time it's working for sure. I have rebooted 2-3 times after installing modules(just to be sure), but all works fine no boot loops or bugs until now.
Update for today:
This was my forth reboot since yesterday and guess what, again I am stuck in bootloops. But I found a solution to not loose data, reflash or restore rom and here it is :
Quote:
Boot into Recovery (Power + Volume Down)
TWRP > Advanced > Terminal command
Create a file /data/data/de.robv.android.xposed.installer/conf/disabled, which causes Xposed to be bypassed:
Code:
touch /data/data/de.robv.android.xposed.installer/conf/disabled
all credits goes to bseos on xda. for finding this solution.
Got it working again. Guess it was a xposed module issue, not sure which one. But I disabled quite a lot of modules which I was not using:
Disabled : Always Expandable Notifications, Amplify, Amplify, AudioPrivacy, Clarity, Enable Notification Ticker on Lollipop, Force Fast Scroll, Hide Network Indicators, Hide Traffic Indicators, Lollipop Power Menu, LP Themer, Per App Hacking, Xposed GEL Settings and XuiMod.
And moved the above post "disabled" file to downloads, rebooted and everything is back to normal.
i think it was xposed GEL Setting because i also have bootloop and it was the only module that i had
