Preach2k
This is one of the Best Car Docks I have seen for the Galaxy Note 3...
iBolt.co - Stay connected with your world.Drive safe and legal by keeping the Galaxy S4, S3, Note 3, or Note 2 in an easy to view position. The 3-piece active car-dock works with Samsung Smartphones from Galaxy SIII up to a Note II with Otterbox Defender case (66-90 mm range). With high quality rubber over-molds, and a dual spring-loaded metal latch, the phone sits firmly in the Dock. The open design also ensures the volume and power buttons are accessible. Protective cases or extended batteries can be used with the xProDock thanks to the spring-loaded latch and extendable feet.
The ChargingArm, with the 9ft "Dock'n Play" cable launches "DockMode" in Galaxy phones. This allows the iBOLT's Dock'n Drive App (free download) to be used as the "home screen". The long cable also allows placement on the left or right side of the steering wheel.
The aux-out feature makes it possible to play all media sound through the car-stereo speakers, including Apps like Pandora, Spotify, TuneIn etc., and GPS navigation for vehicles equipped with a standard 3.5 "aux-in" input.
NOTE: phone calls not routed to car-speakers due to Samsung firmware limitations. Also note that some vehicles may require a low cost ground loop isolator for static free aux-in sound. A Bluetooth hands-free device is therefore recommended when using the xProDock.
With so many hardware and App (Dock'n Drive) functions, we recommend watching YouTube videos for this product. They are found on the iboltproducts YouTube channel.
The ROK II suction Mount features a disc with an adhesive bottom, making it possible to attach directly to any windshield or hard surface on the dashboard. For soft dashboard surfaces, a separate disc is included. The ROK II provides a virtually vibration free driving experience, ideal when capturing HD video while driving. The 17 mm industry standard ball joint used with the mount makes it compatible with alternative mounting solutions like ProClip, KUDA, pedestal bases and AMPS plate, etc.
