xScope - for those who hate mobile Xenforo
EarlyMon
The PearlyMon
Check out "xScope Browser Pro - Web File"
https://play.google.com/store/apps/details?id=sui.mRelease
It's been over a year since the last update, it throws some Java errors for me - but you can quote posts without the cursor jumping around and you can get the actual desktop view.
Hmm, I'll try that when I can. I've never like the mobile version of Xenforo as I've already mentioned in other threads.
xScope was my all time favorite before they overhauled it when ICS came out. I still have the old outdated version on my phone even though it doesn't work right, just because I can still download anything with it. Haven't checked it out in a long time. Like you said, they rarely update. Maybe I'll look at it again. The ICS era update basically ruined it for me, they reduced the number of pages it would cache and they moved the buttons to the top if I remember correctly.
OK - for those interested, you can view androidforums.com in desktop mode in Firefox -
(Copied from another thread)
First - here's a resolution test for the Web and the device that doesn't get things accidentally right or misleading -
http://dev.jeffersonscher.com/resolution.html
Next, here's the instructions to change yours from within Firefox (you'll have to click on the solution button to see it) -
https://support.mozilla.org/en-US/questions/981038
"Assuming the device pixel ratio is closer to 3 than to 1, you can try editing a hidden setting to see whether it improves things.
Open a new tab, and type or paste about:config in the address bar and tap the Enter key on the keyboard. You may want to bookmark this page for future tweaking.
In the search box, type css and then tap the Enter key on the keyboard.
When you find layout.css.devPixelsPerPx tap the Modify button and change the value to 1.0 (typically, you just need to delete the - sign). Tap the OK button.
Switch back to the first tab and reload."
Presto - the desktop version of our site appears in Firefox.
1435172942237-jpg.89746
(low res screen shot due to Tapatalk compression)
