falesh
the rom is completely bug free..sensore problems r one's individual problems..use it n nail it !
downloaded the ROM .... It would be in zip format .......
throw the .zip ROM to ur sd-card ....
Now, after the power down vibration has ended press Power + Volume Up buttons and boot into the ClockWorkMod Recovery. (NOTE: You need to have that CWM Recovery installed onto your cellphones to make this ROM work)
After that, use the Volume Rockers to move up and down and select "wipe data/factory reset". In the next screen click on "yes".
Do the same thing by selecting "wipe cache partition".
The goto "advanced" and select "wipe dalvik cache" and "wipe battery stats".
Go back a level and select "install zip from sdcard", and then select "choose
zip from sdcard".
A flasher will start and it would normally take around 2-4 mins to complete. Let is complete and show "Install Zip Complete" (may vary).
Again go into "advanced" and do a "Fix Permissions". You're done!! Go back into the main screen and select "reboot system now".
It will start booting and first, "Superfone Lite" will be displayed and shortly after that "Blue TerrorTM" boot_logo will come. And right after 5-7 seconds, the bootanimation will start.
using it fr 2 days nw...completely error free n wen i say completely i mean it !![Smile :) :)](/styles/smilies/google/smilie.png)
d link http://www.mediafire.com/?7s2bntu22gua5hq
imp UI updates ! including a new dialer n better icon set ! thanx to firoz
http://androidforums.com/4742684-post1.html
hey hey wen u lik it...y u no thanks
![Big Grin :D :D](/styles/smilies/google/biggrin.png)
zip from sdcard".
![Stick Out Tongue :P :P](/styles/smilies/google/stickouttongue.png)
