Yellow triangle with exclamation mark
charanzia
hello guyz!
i have sony ericsson LT29i replica, i got error too many pattern attempts, unable to access internet from handset now i want to reset hard it by pressing volume down + power on, but i am getting just only Yellow triangle with exclamation mark on screen, now what i need to solve this problem ? ? ?
Please help me regarding this matter.
Thanks All
Is it just producing the yellow triangle warning all the time and won't do anything else, or is this when you try to reset it?
What could have happened though, it might have bricked because of a corrupted or damaged software ROM, due to poor manufacturing quality.
its just producing yellow triangle warning all time!
how do I install new software rom ?
and i want to delete user data to ignore too many pattern attempts, i have no any access for internet to login google account, is there any other option to ignore this error ? ??
this isn't the dead android with yellow/orange/red traingle warning is it? that usually means the same thing as a 'Sad Mac' on Classic Apple Macintosh computers, as in something so serious that the device crashed before completing the booting up, as would be the case with a corrupted ROM, botched firmware update, or corrupt boot loader.
any solution ?
Well if you are stuck at a dead android the software is either corrupt or you have a serious hardware problem. The triangles are various colors, red means bad and yellow I'm not sure.
