Hello, I can't find this in the user guide... does it cost minutes to call my voicemail? If so, can I access my voicemail from a landline and avoid the charges somehow?
thanks
... I can't find this in the user guide... does it cost minutes to call my voicemail?...
garybeck, could you please edit your original post and change the title to sth like "[EDIT]Yes, it costs minutes to check my voicemail"? This way, others browsing this forum will know right away what's up and that this isn't an open question.
Saves everybody a bunch of time, man.![]()
I use Skype for many of my outgoing calls and my caller-id is set to use my cell phone number so using Skype I can now check my voicemail without using any minutesSkype is $3 a month to get unlimited outbound calls over 3g or Wifi
Use Google Voice for making your calls. It doesn't use phone minutes, it uses data, which is free.
No, Google Voice definitely uses your minutes.Use Google Voice for making your calls. It doesn't use phone minutes, it uses data, which is free.
If you use the Voice app it has the voicemail right in the app. If you use Google Voice to check your VM voice mail with your VM phone that will use minutes unless you use Groove to connect GV through WiFi or 3G.Google Voice doesn't use minutes to check voicemail does it?
