Yes the 64 gig Micro SD Class 10 WORKS!!!
Got mine today for $55 from amazon, popped it in, got the typical damaged card error. restarted the phone, you get the same error, then go in and erase card, it will then format and there it is, 59 gigs free!!! Was gonna try the class 6 but decided to go all out and get the class 10. SO EXCITED
Rob
Rob
Glad it worked for ya! BTW, not to burst your bubble or anything, but Class 4, Class 6, Class 10, or UHS-1 are pretty much irrelevant in the phone itself, you would not notice a real difference since the internal hardware is limiting the speed at which it can read/write the data to the card. Now, if you put it in a decent external card reader, the difference can be quite noticeable especially when copying very large files or large numbers of files to and from the card.
