I'm trying to use an 8gb sandisk microsd with my esteem. I reformatted the card to fat32 and inserted it into the slot. It doesn't seem to be recognized at all. I've got root explorer and can't find it anywhere. The only 'sdcard' shown is the 4gb internal one.
When I look under SD card & phone storage settings under SD card I see:
Total Space - 0.98gb
Available space - 682mb
Unmount External SD card
Format External SD card (greyed out)
Is the External SD card referenced above my 8gb physical sdcard? If so if I unmount/format it in the phone would that make it seen/usable to the card?
I have a rooted nook color with cm7 on it so I'm familiar with some of the terms but this is my first smart phone. It is rooted and I've put cwm on it. I'm sure there is something simple I'm missing to get the sdcard usable on this phone.
Thanks for any ideas/help.
After formatting the external sdcard I found that it had deleted all the files on the 4gb 'internal sdcard'. Luckily it was easy to get the files/download the apps again to get back to where I was before.
