Root Z4Root and Huawei Ascend 2
andman433
Havent been able to find anything on this.. Was wandering if the z4Root one click rooting method can be done on the Ascend 2? A friend wants his rooted and Ive never tried and I dont wanna screw the OS Up.. Lemmie know. Thanks!!
hi i have the hauwei ascend 2 and it comes with 2.3.3 stock if you upgraded to the 2.3.5 then you need to downgrade it back to stock and root your phone with the update zip given in this forum hope it works
Danielle
how do you downgrade your ascend from 2.3.5 to 2.3.3? By the way I have a Huawei Ascend II and my carrier is cricket. Thanks for any help.
There are instructions out there on the web and here actually with this info. You must flash the original recovery and flash 2.3.3, then root. It's a fairly simple flash of a .zip file. Then you can proceed to upgrade or just install custom ROMs.
