Accessories ZAGG Full Body Shield
Curt941
Ordered the ZAGG full body shield from Amazon for $15. It was super easy to install, started with the battery cover since i figured if I screwed that up it wouldn't be that big of a deal.
The pieces were all the right size except the battery cover just seemed a tiny bit to wide to fit perfectly. But so far it hasn't peeled off or anything.
The screen protector is nice and is much smoother then the glass.
I would deffinitely suggest this if you don't want a full case but want something to protect your X.
