Zagg screen: Improves outdoors/sunlight?
jlm86
I've had Zagg protective screens in past, and i don't remember them actually improving the ability to see the screen in sunlight/outdoors.
Zagg has said their screen, whether its' new/improved or not, i'm not sure, performs this feature..
Anyone have experience with their claim?
thanks
The orange peel effect is supposed to break up glare and make the screen more visible in sunlight. Maybe it does work, I have an invisible shield on mine and where a lot of people seem to be having trouble reading the screen in sunlight, I'm having no such problems
I've used the new HD version on my S3. I don't think the film itself improves viability but it seems like oil from your fingers does not show up as much and I think the oil itself hurts visibility in sun light. I screwed up my application of the film so I an getting a replacement. The HD is very clear and smooth so you can't really tell it's on the glass.
