Zapp Security - Need Beta Testers!
Reghero
Think Soft needs a variety of people to beta test our new upcoming security application for android; Zapp. Zapp is a fully automated application that relays information that you allow back to our servers and allows you to track it in real-time through our sleek web interface.
  • Background location tracking once installed GPS/Radio depending on which is enabled.
  • Option to send calls to servers.
  • Option to relay messages to servers.
  • Full phone information including SDCard information sent to server.
  • Force phone to wipe SDCard.
  • Force phone to ring at full volume.
  • Generate guest map tracking sessions to allow friends/parents/spouse to track your location.
To get started download and install http://zapp.think-soft.net/Zapp.apk or market https://market.android.com/details?id=com.thinkSoft.Zapp&feature=search_result
Once you have installed the app you can make an account through the application which will allow you to login at http://zappsecurity.com
If you find any bugs or have any suggestions then please report them here or email admin@zappsecurity.com
* Changed background service to consume less battery power and to check first whether or not a data network is available.
* Background service now correctly transmits data when the phone is in a sleep mode.
* Changed the settings menu to give a direct link to the web panel.
* Changed the location tracking code to provide the servers with a cached entry if a valid fix could not be found after a set time.
* Reworked background service to correctly transmit data when sleeping.
* Call sending has been reworked to ensure no loss of performance.
* The phone will now transmit a cached location if it cannot get a fix within the allotted time.
* Web interface rework and cleanup, messages are now fixed and guest sessions have been cleaned up.
Final major update before release.
* Huge update, this includes a UI overhaul, backend rewrite and finalisation of all of the interaction with the web panel.
* Backend rewrite (is more friendly to slower phones when processing calls to send away).
* Web Panel graphical changes.
* GPS Toggle (testing).
* Command receiving has been changed to a passive routine which allows the phone to process the commands when it connects to the network.
* Fixed reported force closes.
