G
ghendo
Guest
i ordered the zerolemon 7000mah extended battery for my s3 and i was really excited so when i finally got it the battery worked just fine the first 2 days then i started to get these problems were my phone would display 30 percent and when i would put it in charge it would show 54 percent so then i rooted myphone and tryed calibrating the battery but that didnt work either i did everything correct what is the fix plz tell me if you know
