I will find one for you. It should just be as simple as grabbing it from a back up of a stock or stock ish back up. Hang on.
BTW, I'm not sure of the proper way to install that apk, but I know that certain apks like the boost voice mail apk will not work properly unless you place them in the proper folder. Do you know about that possible issue?
