ZTE AVID LED COlORS
tiki1516
I wanna make my phone's LED light display different colors than orange,green,and red. I was wondering how I would go about doing that. I have a ZTE AVID 4G, if that helps.
I am not aware of any method to actually change the light display, I know some ROMs have an application built in them that allows such things but the phone will be required to be rooted.
I am not certain which ROM it is, as I am sticking with Stock. You might want to ask your question here.
Avid 4G - All Things Root - Android Forums
They're are apps that can change colors, but root is needed in most cases and your led has to support that color. The avid only has the colors you mentioned anyway I'm afraid. I believe there an led tester app in the play store that can show you what colors are supported on a device.
