ZTE Awe N800 Encryption Unsuccessful (No Root Help!)
Chesty
So my sister had come up to me and given me her old Phone which I was thinking I could use, but she said there was a problem that a "Encryption Unsuccessful" screen pops up and she couldn't do anything about it. So I wanted to get it working and running but the problem is it doesn't have any Root and I'm not sure as to how I can root it but I really would like some help!
Try KingRoot
Alright, I have done that. I'll give you status feedback when I can get some stuff done. Thank you
Try KingRoot
So I managed to get CWM Recovery working from flashing it onto the ZTE AWE, but when I try to insert one of the Custom Roms onto it, it seems to be giving me an error. I tried to look up the error but I cannot find any sort of info about the matter that actually helped, and when I did I couldn't find the right Downloads for it.
set_perm: some changes failed
Installer Error (Status 7)
I'm trying to Install the AWEsome Custom Rom.
Did u wipe data three times then do factory reset what I had to couple times
