ZTE-BLADE(Idea blade) can't access boot-loader
1) I can't perform factory reset in my idea blade(zte-blade)..when i do so,it get stuck at the begining screen showing(green android logo)
2) i cant even access its boot loader(boot menu),i tried almost all the key combinations to get it,but the same way above problem is repeated(i.e stuck on green android logo)
3)i even tried to do above mentioned things using pc command prompt using adb commands,this also resulted in failure,
i cant find any other way,i can again start my phone by re-inserting the battery and switching it on.
can any one plz suggest me a solution in resolving the above mentioned problems.....i would be very thankful if u help me solve this...
thank u in advance....hoping a good and quick responce
