Hi everyone
I have ZTE Blade Q Maxi, of course that no longer works because of his all formatted memory pločice.To means that no Karni and other rooms with the OS and the other, any combination of keys on the device does not work, volume + and inclusion does black screen, volume - and turn lights up green LEDs with a black screen, when you connect with a USB cable to the computer is turned on the red LEDs, and in device manager appears that it is connected to (MediaTek Preloader VCOM USB Port (COM11) and that's all of it. i use Win7 and care whether anyone knows of a turtorijal by-step how to put up all the new but with a USB cable and a computer since I can not turn on the device and put the boot from the SD card or some other solution.
thanks
Grga
thanks
Grga
