Your device should never be a hassle to use,it should be comfortable and very sufficient and suited to your need to use in any situation no matter what it show be;(example) you would hate to be in a real emergency situation and your only chance for your survival is your device's GPS tracking location and your device has been giving you trouble, you definitely don't want to rely on a device that will bootloop on you at any random time,for data factory reset may fix it,in an emergency situation you don't really want to sit and wait for you to have to sign in to your Gmail then wait for your device to sync your contacts then your finally asked will you allow Gps location access to have access to your location, a little bit of an inconvenience when every second is important,in this conclusion my tip is that if your device is not being very compliant and you have had service done on it with no progress in proformance,it only be in your best interest to looking into switching your mobile device to one that at least won't run the risk of giving out on you at the moment when it counts the most,good luck and I hope you find the type of Android device that suites your needs more comfortable!
