I've seen few post about how to fix this. My problem is that message appears as soon as I turn on phone, pushing "okay" makes message go away for second and then comes back before I can go into settings or anything. Then other messages pop up saying unfortunately this or that app has stopped working and pushing okay just makes more pop up. I keep pushing okay in hopes to getting into setting to use the fixes suggested. I got into settings-apps-all-contact storage for a second, tried to push clear cache, while the unfortunately messages keep popping up. I've also have been trying to get to the screen for factory reset but have the same problem with messages popping up before I can do anything.
Is there a way to do factory reset without going to the screen? Is there any button on body of phone to do a reset? Also no new apps have been added to phone in months.
