ZTE Max Duo. In-app menu problems.
Destiny:Rise of Iron. Worth the $30?
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 0 0.0%
  • Hell no.
    Votes: 0 0.0%
  • Total voters
    0
Hello! I'm new to this site and only joined just to ask this question. This question will most likely be a life changer for my phone. I have a couple apps the don't have menu options on screen and require the use of an in app menu. I had a ZTE Majesty before I "upgraded" to the ZTE Max Duo and in the Majesty the bottom right navigation key was able to access this little hidden menu. BUT. on my Max Duo, ITS JUST THE TASK MANAGER. ALWAYS. TASK MANAGER. I looked all over settings and developer options in hopes to fix something. The only thing I can do is change the back and task manager buttons around. I see Android is realising a new phone and I might get it to combat this stupid interface of the Duo. I really don't want to waste money so any help would be greatly appreciated.
Thanks.
The menu button is obsolete and not needed anymore because any app where the menu button would do anything has its own action overflow ( 3 dot menu ). If an app doesn't have a 3 dot menu anywhere on the screen then that means that even if your device had a dedicated menu button it would be useless in that app.
