can someone attach the ota bo6 kikat 4.4.2 please im not rooted or using custom roms .cant find original stock rom online
Two things (not necessarily in order of importance):Hey guys, so I bought one of these off someone as is for $20 bucks. I have access to stock b06 recovery, and dfu but no ftm. Adb comes up as unauthorized when I try to enter adb commands (on KitKat I have to accept debugging while device is in os but I cannot because it will not power into anything other than dfu or stock recovery. honestly don't know how they messed it up but I am wondering if I can fix it. First off the stock recovery has errors and is somewhat dysfunctional but I believe I can use the apply update from SD card to fix, iv just never honestly used the stock recovery so I am unsure how to flash or what would be flashable through the apply update from SD. When I power into recovery it automatically spits out these errors
E: failed to mount /cache (invalid argument)
E: can't mount /cache/recovery/log
E: can't open /cache/recovery/log
E: can't mount or open /cache/recovery/last_log
E: can't mount or open /cache/recovery/last_install
E: can't mount or open /cache/fota/error _code
E: can't mount or open /cache/fota/source_code
Wiping cache partition or wipe data/factory reset in stock recovery spits out the same error codes. Also I have made a live CD with your stormer fix on it. Ran the fix, PC says the device has been unbricked 9412+0 records in 9412+0 records out. But rebooting to recovery leads me back to the messed up stock recovery. Any help at all would be amazing!!
1.You can try using this other unbrick tool that contains ALL partitions for this device in case something other than recovery is messed up.
2. Try flashing this update.zip from stock recovery. It is an official rom from zte that is stock recovery flashable.
Omw home to download now, tyvm!
Unfortunately I don't have any further advise. If you have access to fastboot mode on the stormer you could try manually flashing recovery.When trying to update from stock recovery I get the error
E: failure closing /Dev/block/platform/msm_sdcc .1/by-name/misc
I/O error
Edit: also the tool starts and says unbricking device
8192+0 records in
8192+0 records out
DD: writing '/Dev/sdb' : Input/output error
1+0 records in
0+0 records out
That is indeed an assert error, however it is strange that you get it with stock recovery and the stock update.zip. Not sure where to go from here. Sorry man.Ok so progress made! I don't have access to fastboot or adb because the device was already updated to 4.4.2 (where I have to authorize adb and fastboot while os is running, I can't access the os) .running the fix_full.ISO must have fixed things a bit, now whenever booting to recovery I get no error messages, also the .ISO tool runs completely through without error or hanging. I can boot the system! It goes past boot screen and automatically says encryption unsuccessful. I tried to install update via SD card through stock recovery and run into this error
Assert failed: getprop ("ro.product.device") == "stormer | | getprop ("ro.build.product") == " stormer"
E: error in /tmp/sideload/package.zip
(Status 7)
Installation aborted
I looked up status 7 error and found it had to do with the asserts line in the updater script and removing it is kind of like a bypass. Tried to edit it and repackage ota update with edited updater-script but when I tried to install it gives me a footer is wrong error, am I doing something wrong? Familiar with any of these errors? And as always thank you for help! I see you guys have done a lot with the max since we were trying to test out the philz bugs![]()
@Odin89 - I should have said so before but I ran out of time...you can't edit the updater-script in an official rom and still be able to flash it in stock recovery. It breaks the signature in the zip.
edit: Have you tried wiping data from stock recovery? I ask because the encryption the error refers to is in the /data partition.
Ah I see. Yes I have tried to wipe data/factory reset in stock recovery as well as clearing cache. If the ota updates update scripts aren't recognizing the phone as the stormer would it be possible it is a hardware malfunction, such as corrupt data partition? Your tool recognizes it. Its curious.
I have had similar problems with the update zip for the ZTE Sync.. Kept saying it wasn't a warp4 or something. Do you think there's a device name change involved in the update?
It may help if you could access adb in order to issue the commands. Unfortunately you said you can't so it won't workHow would I be able to tell? Also I found this sry I forget link just screenshotted it and uploaded to my db later. https://www.dropbox.com/s/7uvb17qjtaj958i/Screenshot_2016-02-15-20-09-44.png?dl=0
Would this help? I would use it but somewhat unsure the " and >> uses
