ZTE Overture dev discussion
METDeath
Code:
cat /proc/partitions
major minor  #blocks  name
 179        0    3817472 mmcblk0
 179        1       8192 mmcblk0p1
 179        2       8192 mmcblk0p2
 179        3       8192 mmcblk0p3
 179        4       8192 mmcblk0p4
 179        5       8192 mmcblk0p5
 179        6       8192 mmcblk0p6
 179        7       8192 mmcblk0p7
 179        8      24576 mmcblk0p8
 179        9       8192 mmcblk0p9
 179       10       8192 mmcblk0p10
 179       11       8192 mmcblk0p11
 179       12       8192 mmcblk0p12
 179       13       8192 mmcblk0p13
 179       14      73728 mmcblk0p14
 179       15      16384 mmcblk0p15
 179       16      16384 mmcblk0p16
 179       17      16384 mmcblk0p17
 179       18    1056768 mmcblk0p18
 179       19       8192 mmcblk0p19
 179       20       8192 mmcblk0p20
 179       21     311296 mmcblk0p21
 179       22    2138112 mmcblk0p22
 179       23       8192 mmcblk0p23
 179       32    3870720 mmcblk1
 179       33    3868640 mmcblk1p1
Code:
ls -al /dev/block/platform/msm_sdcc.1/by-name
aboot -> /dev/block/mmcblk0p13
boot -> /dev/block/mmcblk0p15
cache -> /dev/block/mmcblk0p21
fsg -> /dev/block/mmcblk0p10
grow -> /dev/block/mmcblk0p23
misc -> /dev/block/mmcblk0p19
modem -> /dev/block/mmcblk0p14
modemst1 -> /dev/block/mmcblk0p11
modemst2 -> /dev/block/mmcblk0p12
persist -> /dev/block/mmcblk0p8
recovery -> /dev/block/mmcblk0p16
rpm -> /dev/block/mmcblk0p4
sbl1 -> /dev/block/mmcblk0p1
sbl2 -> /dev/block/mmcblk0p2
sbl3 -> /dev/block/mmcblk0p3
splash -> /dev/block/mmcblk0p17
ssd -> /dev/block/mmcblk0p9
system -> /dev/block/mmcblk0p18
tombstones -> /dev/block/mmcblk0p20
tz -> /dev/block/mmcblk0p5
userdata -> /dev/block/mmcblk0p22
ztecfg -> /dev/block/mmcblk0p7
ztelk -> /dev/block/mmcblk0p6
(stripped all the extra from the above command)
Attached is the config.gz (renamed to .zip for upload).
build.prop
Code:
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=JZO54K
ro.build.display.id=Z995V1.0.0B06
ro.build.version.incremental=20130513.102020.28172
ro.build.version.sdk=16
ro.build.version.codename=REL
ro.build.version.release=4.1.2
ro.build.date=Mon May 13 10:20:56 CST 2013
ro.build.date.utc=1368411656
ro.build.type=user
ro.build.user=heduolian
ro.build.host=zte
ro.build.tags=release-keys
ro.product.model=Z995
ro.product.brand=ZTE
ro.product.name=P893A20
ro.product.device=becky
ro.product.board=becky
ro.product.operator=ATT
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=ZTE
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=msm8960
# ro.build.product is obsolete; use ro.product.device
ro.build.product=becky
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=P893A20-user 4.1.2 JZO54K 20130513.102020.28172 release-keys
ro.build.fingerprint=ZTE/P893A20/becky:4.1.2/JZO54K/20130513.102020.28172:user/release-keys
ro.build.characteristics=default
# end build properties
# system.prop for surf
rild.libpath=/system/lib/libril-qc-qmi-1.so
rild.libargs=-d /dev/smd0
persist.rild.nitz_plmn=
persist.rild.nitz_long_ons_0=
persist.rild.nitz_long_ons_1=
persist.rild.nitz_long_ons_2=
persist.rild.nitz_long_ons_3=
persist.rild.nitz_short_ons_0=
persist.rild.nitz_short_ons_1=
persist.rild.nitz_short_ons_2=
persist.rild.nitz_short_ons_3=
ril.subscription.types=NV,RUIM
DEVICE_PROVISIONED=1
debug.sf.hw=1
debug.egl.hw=1
debug.composition.type=gpu
ro.sf.lcd_density=240
dalvik.vm.heapsize=36m
debug.enable.wl_log=1
debug.mdpcomp.maxlayer=4
debug.mdpcomp.logs=0
# system props for the cne module
persist.cne.bat.range.low.med=30
persist.cne.bat.range.med.high=60
persist.cne.loc.policy.op=/system/etc/OperatorPolicy.xml
persist.cne.loc.policy.user=/system/etc/UserPolicy.xml
persist.cne.bwbased.rat.sel=false
persist.cne.snsr.based.rat.mgt=false
persist.cne.bat.based.rat.mgt=false
persist.cne.rat.acq.time.out=30000
persist.cne.rat.acq.retry.tout=0
persist.cne.feature=1
ro.hdmi.enable=true
lpa.decode=true
lpa.use-stagefright=true
#system props for the MM modules
media.stagefright.enable-player=true
media.stagefright.enable-http=true
media.stagefright.enable-aac=true
media.stagefright.enable-qcp=true
media.stagefright.enable-fma2dp=true
media.stagefright.enable-scan=true
mmp.enable.3g2=true
# system props for the data modules
ro.use_data_netmgrd=true
#system props for time-services
persist.timed.enable=true
# System props for audio
persist.audio.fluence.mode=endfire
persist.audio.vr.enable=false
persist.audio.handset.mic=analog
persist.audio.lowlatency.rec=false
# System prop to select audio resampler quality
af.resampler.quality=255
# System prop to select MPQAudioPlayer by default on mpq8064
mpq.audio.decode=true
# system prop for opengles version
# 131072 is decimal for 0x20000 to report version 2
ro.opengles.version=131072
#system prop for Bluetooth hci transport
ro.qualcomm.bt.hci_transport=smd
# system prop for requesting Master role in incoming Bluetooth connection.
ro.bluetooth.request.master=true
# system prop for Bluetooth Auto connect for remote initated connections
ro.bluetooth.remote.autoconnect=true
# system property for Bluetooth discoverability time out in seconds
# 0: Always discoverable
#debug.bt.discoverable_time=0
#system prop for switching gps driver to qmi
persist.gps.qmienabled=true
# System property for cabl
ro.qualcomm.cabl=0
# System props for telephony
# System prop to turn on CdmaLTEPhone always
# removed by yangyiming 2013.01.17
# telephony.lteOnCdmaDevice=1
# System prop for sending transmit power request to RIL during WiFi hotspot on/off
ro.ril.transmitpower=true
#Simulate sdcard on /data/media
persist.fuse_sdcard=true
ro.hwui.text_cache_width=2048
# Supports warmboot capabilities
ro.warmboot.capability=1
#snapdragon value add features
ro.qc.sdk.audio.ssr=false
##fluencetype can be "fluence" or "fluencepro" or "none"
ro.qc.sdk.audio.fluencetype=none
ro.qc.sdk.camera.facialproc=false
ro.qc.sdk.gestures.camera=false
#property to force camera shutter sound on speaker
ro.camera.sound.forced=1
#ZTE_LCF_20130131 property to turned off Qualcomm
Can you get me these partitions?
Code:
su
mkdir /sdcard/blocks
cat /dev/block/mmcblk0p1 > /sdcard/blocks/mmcblk0p1
cat /dev/block/mmcblk0p2 > /sdcard/blocks/mmcblk0p2
cat /dev/block/mmcblk0p3 > /sdcard/blocks/mmcblk0p3
cat /dev/block/mmcblk0p4 > /sdcard/blocks/mmcblk0p4
cat /dev/block/mmcblk0p5 > /sdcard/blocks/mmcblk0p5
cat /dev/block/mmcblk0p6 > /sdcard/blocks/mmcblk0p6
cat /dev/block/mmcblk0p7 > /sdcard/blocks/mmcblk0p7
cat /dev/block/mmcblk0p8 > /sdcard/blocks/mmcblk0p8
cat /dev/block/mmcblk0p9 > /sdcard/blocks/mmcblk0p9
cat /dev/block/mmcblk0p10 > /sdcard/blocks/mmcblk0p10
cat /dev/block/mmcblk0p13 > /sdcard/blocks/mmcblk0p13
cat /dev/block/mmcblk0p14 > /sdcard/blocks/mmcblk0p14
cat /dev/block/mmcblk0p15 > /sdcard/blocks/mmcblk0p15
cat /dev/block/mmcblk0p16 > /sdcard/blocks/mmcblk0p16
cat /dev/block/mmcblk0p17 > /sdcard/blocks/mmcblk0p17
cat /dev/block/mmcblk0p19 > /sdcard/blocks/mmcblk0p19
cat /dev/block/mmcblk0p20 > /sdcard/blocks/mmcblk0p20
cat /dev/block/mmcblk0p23 > /sdcard/blocks/mmcblk0p23
If you post the system.ext4.tar.a file from an unmodified system backup I will put some stock roms together.
Could you elaborate on what you want? I'm more than a little new to doing actual dev work and am just a technical user with a spare device trying to help out others.
Did you make a backup in PhilZ before making any modifications to your device? If so, please upload the system.ext4.tar.a file from that backup.
Anyone working on a custom ROM for this device? A CM11 project was off to a good start by hroark13. It was a great idea on the multi device compatibility install. I recently tried it out and the rear mic was being used for phone calls instead of the front mic. Otherwise it was a collaboration of work. Wonder if anyone ever reworked it?
http://androidforums.com/official-u...loper-tester-thread-zte-msm-8x30-devices.html
Also,
There is a bunch of ROMs for the AWE but none for the overture yet. Can the Nameless ROM be adjusted work?
John
