ROMs ZTE Radiant - Preferred Network Problem (Jelly Bean)
mcasdorph
I was using a custom rom by hroark13:
http://androidforums.com/official-u...loper-tester-thread-zte-msm-8x30-devices.html
He has since closed the thread on the rom and probably isn't going to do anything else with that rom. I was having a problem even accessing the "Phone Information", turns out you can't use *#*#4636#*#* on this phone, but I did find a code that did work.. *983*3640#
I am currently throttled and I'm stuck on presumably 2G, my problem seemingly starts here, I should be able to connect to 3G since the highspeed LTE data hit the limit and goes to 3G, the problem is, in Phone Information it appears to be stuck on GSM (PRL), and I can't get it to change and stick. what could the cause of this be?
