Root ZTE Sequent. Need immediate response.
Diathrane
I bought the Sequent since it was first debuted, i had it rooted a couple days later. I haven't really got into the rooting possibilities until now, and i downloaded Beats Audio installer (star) root. and then i had a nice phone that couldn't use CDMA/Evo towers or get any type of signal. I factory reset, i could use WiFi again, but still no SMS/Calls/MMS. I also want to figure out how to fix the inverted camera, i use Skype and i cannot fix this issue, but to continue on what are your recommendations ?
Thank you for your time.
/Diathrane Von Burara/
Reinstall your rom and you will be fine.
I did, thanks for the idea. But do you know if I have to edit my build.prop to fix my upside down camera?
