You can do what I did I got one used like you did for my sisters kid no sim so I went to best buy and brought an zte warp took the simcard out and returned the phone, if you plan on buying one look to spend just 40 for the card better going to best buy
If the phone isn't active it might work but..seriously that is shady times like that I'm glad I don't work in a super professional environment because I can tell you to gtfoSo what did you tell Boost to get your stolen UICC card paired with your phone?
Sprint sims arent hot swapable like GSM sims. They are tied to your phone. Just get a replacement from Boost like DD said.
