Root 01-12-2011 dhd
cxzFTW
Hello everyone !! I am new to the forums :)
So past 2 last days iam trying to DOWNGRADE / ROOT my phone but without success
Trust me i've try'ed everything -,-
Maybe theres a frimware for root / downgrade show'd up on last days ( and i cant find it )
DESIRE HD
Android system ver
2.3.3
HTC SENSE
2.1
Dont know how to translate from polish next word for version anyways
12.54.60.25U_26.09.04.11_M2
2.6.35.10-gd2564fb
htc-kernel@and18-2 #1
THU JUN 9 14:20:29 CST 2011
Compilation numer 2.50.161.3 CL12325 release-keys
Number software 2.50.161.3
And yeah iam newbie to the Android :(
I would be happy if some one 'll give me good solutions
Thanks for repply , well tryed also this was atleast trying to work with it but after 3 or 4 hours with hack-ace iam pissed off ;) whole time getting msg "really read the effen manaual " for sure i know with code to copy
any solutions? :/
any solutions? :/
the code is in the same folder as the folder where you are running the exe from. if you are looking for it in the temp folder, it would always give you the incorrect code...
ill post here a video with the hack-ace thing
Code:
http://speedy.sh/6qdek/hackingthingpissingofff.avi
to be sure please check it :)
just get Ubuntu Live cd and got a problem well... ill pase terminal here
ubuntu@ubuntu:~$ wget http://droid.neolobster.com/roms/aahk-29102011.zip && unzip aahk-29102011.zip[/COLOR].zip && sudo ./hack-ace.sh
--2011-12-01 20:08:21-- http://droid.neolobster.com/roms/aahk-29102011.zip
Resolving droid.neolobster.com... 216.139.210.185
Connecting to droid.neolobster.com|216.139.210.185|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 109788637 (105M) [application/zip]
Saving to: `aahk-29102011.zip.2'
100%[======================================>] 109.788.637 1010K/s in 2m 23s
2011-12-01 20:10:45 (748 KB/s) - `aahk-29102011.zip.2' saved [109788637/109788637]
unzip: cannot find or open aahk-29102011.zip[/COLOR].zip, aahk-29102011.zip[/COLOR].zip.zip or aahk-29102011.zip[/COLOR].zip.ZIP.
No zipfiles found.
ubuntu@ubuntu:~$
Sorry, that was my fault. I forgot to remove colour tags of something I was going to highlight in a prev post. Try the below.
Code:
wget http://droid.neolobster.com/roms/aahk-29102011.zip && unzip aahk-29102011.zip && sudo ./hack-ace.sh
:o
Ok, copy and paste the text from the cajun.txt again. Where it uses a , in the passcode, change that to a .
So RTEM-18:27:35,59 would become RTEM-18:27:35.59
Just a thought, if you're using a Polish mapped keyboard, I know the , and . are reversed compared to an English one.
If that doesn't work, I'm stumped, sorry. :(
the code re-generates everytime you try the hack kit, so you will have to come of the code screen for itto regenerate.
Done everything on linux ( wow i did it ) THANKS !!
Btw on linux the code for aahk was other than on Win ... strange
Glad you're all sorted - it's great when it finally works... I rooted before the AAHK (when the process was a lot more involved) and it took ages to get over all the hurdles!
Hope you enjoy your rooted device! :)
