Root 1 click help
Gracie10
Hi all. I tried to use CIH2 today and found out that there was a problem with being rooted. I plugged my Droid into the computer to try and Root it again with 1 Click but :confused:there was an error message. It said cannot copy boomsh permission/access denied. I went into Superuser and there were no apps listed. Terminator emulator said after I typed in su that access was denied. I have no clue of what to do now. I would love any help or suggestions at this point. I am so lost. Thanks in advance! Forgot to mention that I lost access it seems after an ATT update.
pdate 2.3.6 is not rootable yet Gracie.. That's probably the reason you are having problems.. Unfortunately if you didn't do the 4ever root process before going up to AT6T`s update 2.3.6 you can either wait until the root option is available OR go down to 2.3.5, do the 4ever root process and then go up to 2.3.6 without loosing any root privileges.!.
Not too sure what CIH2 is but after reading your post it sounds to me like you have upgraded to 2.3.6 and are now without root.
Download the root file HERE
Connect your phone to your pc
Unzip the file and then double-click "Click-To-Root.bat".
A few short seconds later you'll be rooted again on 2.3.6 ;)
