PMTerp
Member
I use a spreadsheet a lot on my Inc through Documents To Go. The problem that I have is that whenever I select an empty cell it brings up my default keyboard. I then have to hit the Number key but after a single key press, it goes back to letters. If I touch in the input line at the top of the screen it will stay numbers until I go to another cell but then its back to letters again.
I know you can have multiple keyboards and change between them, does anyone know where I can get just a numeric keyboard? I'm even willing to consider a bluetooth 10 key pad if I can find one compatible.
