Really? I always thought the carrier would do that at their end...
I checked and my phone does indeed have that folder. There's a couple files in it as well.
i currently have a motorola xprt from sprint and service is boostmobile and i cant get the hot spot to work because it dont have it could i get any help? i dont know what is root or other things but give me an idea on houw to make my motorola from boostmobile to have my own hot spot to workThe 10 bucks a month is for legitimate tethering. Technically its a violation of the terms of service if you root your phone and tether. But I've been with boost since the prevail came out, tethering up 4gb a month with no issues. But there is always a chance they could disconnect you
Is it normal to go past 2.56 GB in a month time???
40gb a month? You sure? With Sprint/Boost's abysmal speed that is quite a feat. Are you on 4g? Aside from the speed issue what the he** do you do with it? Netflix 24/7?I literally use between 40 to 60 gigs in a months time. Is that normal?...........probably not. But I'm with sprint, and unlimited data is great!
I'm an intensive user but I use about 150-200 megs a day at work and I work 6 days. I might put a dent on Boost (being that I'm on the last rung of shrinkage) but they've never called me or indicated that I'm causing problems.
did anyone ever post instructions on how to make this phone a hotspot? or maybe just direct me to the "how to's for dummies' area lol.....I hate this phone but if i could enable hotspot i might not throw it out the window.i currently have a motorola xprt from sprint and service is boostmobile and i cant get the hot spot to work because it dont have it could i get any help? i dont know what is root or other things but give me an idea on houw to make my motorola from boostmobile to have my own hot spot to work
