Help 100% cpu
prolax
My phone has randomly started sitting on 100% CPU for no reason - nothing running (killed all apps with advanced task killer). All I have to do is run an app called SetCPU and change one of the scaling settings, doesn't matter what it's on to what it' changes to, and it fixes it for a bit.
Will randomly reboot when it sits on 100% load and obviously uses up battery.
Using the RevolutionHD rom
USB Debugging is on
Less than a week old
Was working fine one afternoon, then noticed it start to reboot next to me. Nothing had been installed that afternoon, but numerous amounts of apps were installed the day prior.
Any ideas?
EDIT: Also, used watchtower to see what was using all the CPU during the laggy moments, "system_server" was using a very high percentage of it.
Do you have the HTC sense sync on? I know you have a custom ROM but I had a problem with the HTC Sense:remote process. I disable HTC Sense Account in the sync section, rebooted my phone and it was fine...
i guess this question has been pumped into the RevolutionROM forum amongst the XDAs right?
Not as of yet, I thought I would try my luck here first. I'll give it a shot there as well now tho.
Yup, I have already disabled my HTC Sense Account and still get issues, cheers for the input tho.
