WHAT ELSE CAN I DO?
1. wiped everything, including a factory reset.
2. reflashed the rom. (titanium automatically reloaded all my apps)
3. deleted ALL apps.
STILL 100% wake time.
check your htc facebook version if it is 1.0 it keeps your phone awake. i think there is a way to update it to 1.3 or something that fixes this.
Spare Parts > End button behavior > go to sleep
Solved.
your contacts should sync through gmail.
have you ever used facebook on your phone before or even have a facebook account?
i do not have a facebook account and my contacts sync fine. if you want to keep facebook search the forums on how to update the HTCfacebook app. i think there was a fix for the battery drain it caused. i never looked for it as i do not use facebook at all.
It's seriously doubt it's your phone. When you finally isolate what's causing it, it will likely be one of those forehead slapping things that will suddenly seem ridiculously simple and obvious. If you wipe again, only add apps one at a time, then leave it alone for awhile each time and see how your phone behaves. I know it's annoying, but you'll find it. Hang in there.just wiped my phone. (using Amon RA)
re-flashed the newest fresh.
wiped dalvik
wiped cache
didn't install anything
and STILL 100% awake time?
is there something wrong with my actual phone that's causing it stay awake.
Yes, I have a facebook account and use it.
when i say contact sync i don't mean the gmail to phone sync, i mean when facebook goes in and changes all your photos and syncs facebook and your contacts together.
I'm getting so frustrated with this. I've wiped my phone at least 10 times in the last few days and i went thru and added apps one by one 2 times now, and it seems my phone is sleeping and then BAM is stops sleeping.
i don't know what to do at this point. I'm getting so frustrated.
there should be 2 face book apps on your phone. the one i was talking about the version# is the one that comes stock. its called HTCfacebook not the one from the market. i'm not sure how to check the version or how it updates, but it was keeping my phone at 100% wake. others reported this as well. i know very little about using facebook i just know removing both apps solved my problem.
you are rooted right? you will need to have root explorer to be able to remove this app.
so my having NOT signed into the facebook sense could be why i am seeing my phone sleep now?
is it just the facebook app from the market that's having problems?
or is the the facebook HTC sense?
or is it both???
i'm not 100% sure but i was under the impression it was the HTCfacebook. i could be totally wrong tho. i removed them both at the same time.
i guess just try removing them one at a time. i am not really sure how facebook or the 2 apps even work.
if we know that facebook is the issue you are having. i would start a new thread in the general section and just title it facebook. then tell your story and ask about the the 2 apps. i'm sure there is someone out there that knows facebook better then i do and they just aren't here reading the rooting section.
sorry i can't help you too much on which facebook does what, or even why there are 2.
