If you tap on the screen where you want the focus the device moves its focus point to that part of the screen. I believe it will attempt to lock focus on this part instead.
You can try this by taking a couple pictures of a room with good depth of view. For instance stand in one location in the room and tap to focus on the sofa near you. You should see the phone bring the sofa into focus and the items in the rear of the room lose detail. Then if you tap to focus on something in the rear of the room they should come into focus and the item closer to you should lose their crisp focus.
Try this and report back.
Yeah I've done that, it only happens on close objects (like an inch away from the camera). It's a bit better when the camera is set to Macro Mode though.
