Help 16gb memory card
I agree with felix822. If you have another reader/input to you pc, I'd try a format on the card. You might also try putting your original card back into the phone and make certain it works. Then go to apps>settings>SD and phone storage and unmount that card... remove it... then try your new card and mount it. If all else fails.. take the card back if it is truly DOA. Good luck
