Why will the triumph not recognize all of the music i put on the sd card? i plug it in to the computer and can view ant listen to the music, just not through the phone.
Is it not recognizing just some of the music? Then you may have a file type issue or a drm issue. What is the file type(s) that the phone doesn't play but the pc does? What are you playing them with on the pc side?
The stock Android music player will play .mp3, but not compressed .wav. You can convert them to mp3 (what I would do) with a tool like Audacity, or use something like waveplayer
