go to the recovery screen and install it from there. if you dont have the rom on your sd card you can plug the kindle in and mount the usb from recovery then add it to a folder then flash it after that.
when you plug it in, check the drivers and see if that shows up. delete the drivers then plug the kindle back in. should automatically install the drivers. when you plugged it in, you pressed the mount button right? (just wanna make sure you did that incase you forgot)
