D
Deleted User
Guest
On 1.5, there were three check boxes in the locations menu in settings. I think they were:
Use wireless networks
Use network (I assume this is cell network)
Use GPS
I had the first two checked and GPS turned off.
On 2.1, the first and last (wireless networks / gps) have check boxes but the middle one does not. When I click the middle on, I have a yes / no option. But, when I turn GPS off, it turns the middle option off and I get the location symbol on the notification bar with a line through it. If I turn the middle option on, it checks the GPS also. It seems the "use network" and "use gps" have to both be on or both be off.
So I guess you cannot have use wireless networks / use network turned on and GPS turned off??? Can anyone confirm this is how it is supposed to work. Thanks.
Use GPS
