2.1 and Text messaging.
Syv3n
Ok so I know this is a known issue but is there anything I can do at all? This is the only complaint i have since upgrading to 2.1 but its a pretty big one. I have tired default messenger and handcent and still get the "Not delivered" message althought it was delivered. Yes I did the *228 thing also. Any other app, or fix I could do?
Same issue here. I get the undelivered messages from handcent every other text or so. Funny thing is the are actually going through. Anyone?
Only solution so far is to *uninstall* Handcent (not just disable it) and try the stock messaging app or ChompSMS instead. Chomp isn't in the market yet, so you have to download it from chompSMS.
I have been using chomp before and after 2.1, no issues at all. 1.5 and 2.1 still can't send pic messages to iphones with any messaging app though
*knocks on wood*
My Eris actually has no trouble sending/receiving SMS and MMS since upgrading to 2.1. I'm just using the stock messaging app.
I had the same problem with HandcentSMS. I uninstalled completely and am currently using the native Messaging app with zero problems.
