motionxxusxx
So far I seem to be losing battery a little bit quicker. It will take a few days to get a good idea of the battery life.
...I wonder if it's because I'm playing with the phone and trying to get it back to all of my old settings and apps.
You can go to Settings > About Phone > Battery > Battery Use and it will tell you, by percentage, what is using your battery the most.
Disable Auto-Sync
Settings > Accounts & sync > Background Data
Should help those of you concerned with battery life post 2.1.
somethings up, my awake time is pretty high. The only difference between my 1.5 and 2.1 setup, is the fact that I now have 2 gmail accounts setup.
Don't touch your phone for like 1 hour and see if your awake time is still high.
Ummm yeeeaaa..............should I quit smoking cigarettes and shooting heroin at the same time?
When I go to this it only gives me an awake time now, but no percentage, which it gave before I did 2.1
